Why does the flex cable and chargerport keeps getting damaged?
I have an A40 but the charger port or flex keeps getting damaged every time i replace it.It looks like something else is the problem does anyone have any suggestions?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 137
4条评论
@lms7777 what do you mean by getting damaged? What happens to your charging port? what charger are you using?
由 oldturkey03 完成的
It will get damaged if you're rough with it. Can you upload some pictures of the part?
由 [deleted] 完成的
@oldturkey03 by charger port or flex cable getting damage i mean that my phone stops charging and in order to let it charge again i need to replace the part (Charger port/flex cable) thats not working well.I'm using a type C charger
由 Lucarcio 完成的
@lms7777 that sounds like a bad charger. Use a different one and see if that makes a difference.
由 oldturkey03 完成的
