Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Texas Instruments TI-30Xa Teardown guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 209
3条评论
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
由 F Dryer 完成的
@notbroken oh ok thanks
由 Papaya Bear 完成的
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
由 HelloMacOS 完成的
