跳转到主内容
Smaller brother of 300 in 6cy coupe.
2 个问题 查看全部
While car in d, car doesn't move, and rpm raise
When I put gear in drive, the car doesn't move and the rpm meter goes up
Update (01/29/2023)
While in reverse, it work but d-1 and 2, no. Rpm meter raises when I accelerate. Year of car is 2014 chryselor 200.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@cudang how about R and 1 and 2? What year is yours?
完成的
Reverse work, but d1 and 2 doesn’t. And the year is 2014 chryselor 200
完成的
添加一条评论
1个答案
Chrysler is somewhat prone to bad transmissions, and this is usually one of the symptoms of a bad tranny with them. However, this is NOT cheap so you do want to do a proper diagnosis.
What I would look at first is the range sensor and see if there's an issue with one of the solenoids first, but this usually requires a high end scan tool like an Autel used by a mechanic unless you can find one for $150-200 (maybe $250) with manufacturer specific diagnostic testing. Try something like this: INNOVA-CarScan-Pro-5210, othwerwise you will need a scan tool like this: FOXWELL NT624
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danny 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 6
总计 129
