Charging port replacement issue
So the tablet i have was not on the choose your device section, it is the sasmsung galaxy tab a7 10.4 in i believe the model number is SM-T500. Anyway at one point i dropped it and form then on the tablet would only charge when the cable is pressed in at an angle. I have tried multiple charging cables on this device and others that i have so i know its not the cables. I opened the tablet and bought a new charging port, Im not sure if the 2nd one i bought was doa or what but it does not take a charge either. there are these 2 metal prong type things on the bottom of the charging port i dont know if those need to be touching the case for ground or what the deal is. I have ordered an additional charging port replacement but i was wondering if anyone has had similiar issues and what you found works. As far as i can tell this is the only issue with the tablet.
Left one is replacement, Right is from the tablet
@jmitchell94 can you post some pictures of all of this with your QUESTION? That way we can see what you see. 在已经存在的问题里加入图片
由 oldturkey03 完成的
added images
由 jeff 完成的
If you can at least post the picture of the charging port you ordered for . Then a proper insight can be given on. If it’s actually the proper charging port or not
由 Ubiquicktous Solutions 完成的
added images
由 jeff 完成的
