跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
2 battries in and still wont turn on
Hello all!
Iphone 5c model #A1532
Got 2 batteries off of amazon thpught the first one was bad out of the box because it shows a charge of 0.7A and immediatly drops to 0 then back to 0.7A it just repeats this cycle endlessly. Also wont turn on the screen or anything else. I dont have the hardware to test if the battery has charge or not and I also dont have the hardware to check the screen too ensure its not damaged or anything.
Initial problem was the phone would not stay on and also would not boot once battery charged I got it a couple of times enough to back it up but became unreliable.
Figured a new battery would fix it but maybe the Motherboard is dying?
Ill ship it to someone if they want to play with it otherwise comments and suggestions are welcome.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
connect to a pc to check if it connects, if not try with only the screen, battery and port connected to rule out other part issues, if none of these work its probably a board issue. if your in the uk i could take a look for you if you like
完成的
Ya it doesnt power up at all. But I fugured that's because the battery doesnt work? It acts like the battery isnt even in there. Should it still connect to a PC even with no battery? I have tried connecting ut before and got nothing from it.
I can still send it to you in the UK I dont mind.
完成的
添加一条评论
2个答案
最有帮助的答案
@p38sheep - Ebay, Amazon, etc are known for VERY VERY Questionable batteries!
iFixit On the other hand has reputable Parts&guides.
As @tech_ni said If it shows up on a PC We can rule out the other issues...
Honestly I bet it was that it was an amazon battery.
Part: iPhone 5c Battery
Guide: iPhone 5c 电池更换
P.S I would be willing to play around with it If you ship it to me or your not willing to fix it
Replace a dead or dying battery in your iPhone.图片
产品
iPhone 5c Battery
$29.99
这个答案有帮助吗?
得分 2
3条评论:
i would also add mobile sentrix and injured gadgets as purveyors of quality batteries
完成的
I love more resources thanks for adding this!
完成的
@beekerc - Yes! Thanks for the Info! :-)
完成的
添加一条评论
It does sound like a motherboard issue to me personally, but if you can get it to appear on a computer like Ben said then you can rule out that for the most part.
这个答案有帮助吗?
得分 1
1条评论:
Reputable made me giggle, loads of quality batteries for sale on eBay if you know where to look.
完成的
添加一条评论
添加你的答案
P38sheep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 150
