Power throughout device but it doesn't turn on?
I've tested all of the main points and just random spots throughout the board with power plugged in and the power flows through the whole thing but still, when I have it all together it doesn't turn on, like the little led on doesn't turn on. I thought maybe the led was out so I tried to turn it on while it was connected to the tv but nothing happened. I was wondering if this is a possible fix because everywhere I look online just says to solder the power plug joints back to the board but there not broken.
Update (01/22/2023)
of the bottom of the board
of the top of the board
another of the top
Update (01/22/2023)
okay, the one outlined in red is a bit resistant (its coming up about a 15-20 on my multimeter), and the blue one has no continuity at all.
@octopie is your power LED does not come on, that means your PS2 does not get power. Your PS2 is a PlayStation 2 Slimline?
由 oldturkey03 完成的
yes, it is a slim, when I have it plugged in and I test it with a multimeter it says that there is power moving through it, roughly 18 volts, so I'm not entirely sure what it would be...
由 Damien Simons 完成的
@octopie there were issues with the power supply on the PS2 slim. Have you checked yours?
由 oldturkey03 完成的
@octopie good and thanks for the pictures. Now, let's see what we can come up with.
由 oldturkey03 完成的
@oldturkey03 Yeah, I'm fixing this for a friend and I tested their power supply with a ps2 I have and know works and it worked for that one and my working power supply didn't do anything for this one. Also, posted more pictures.
由 Damien Simons 完成的
显示更多的7条评论
