跳转到主内容
Installation of an Samsung SSD 870 Evo
Hi
I purchased a Samsung ssd 870 evo hard drive, and I am trying to install this. But the connection is not the same as the old hard drive. How can I get this installed? Is there a new cable that I can buy or some other trick?
Glad if you could help me
Eric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sadly, Eric Apple did their own thing with their blade SSD’s.
The Samsung 970 EVO SSD is a M.2 SSD and is not designed to work in your system without an adapter (if it supports PCIe/NVMe drives which this system doesn’t).
This MacBook Pro is an mSATA based system as you can see in this great guide The Ultimate Guide to Apple’s Proprietary SSDs so this SSD won’t work as it’s a PCIe/NVMe drive. You will need this SSD OWC Aura Pro 6G SSD and follow this guide MacBook Pro 13" Retina Display Late 2012 SSD Replacement
Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013.图片
产品
OWC Aura Pro 6G SSD
$49.99
这个答案有帮助吗?
得分 0
2条评论:
870 EVO is 2.5 inch boxy SATA SSD.
完成的
@tomchai - Yes, the 870 is a 2,5 SATA drive given the system chosen it wouldn’t physically fit and the clue of the connector being different tells us Eric got a 970 M.2 drive and had a slip of a digit here. While similar it still won’t work as it’s a PCIe/NVMe drive and this series only works with mSATA.
完成的
添加一条评论
870 EVO is designed as an 2.5 inch spinning drive replacement SSD, the case physically will not fit in a Retina MacBook Pro.
Even if you take out the case and put in the naked board directly, getting an adapter will be extremely tricky. Most adapters are designed the other way around, converting Apple SATA SSD into generic SATA, opposite of what you want.
At this point it is easier to just buy a correct SSD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eric lorentzon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 1,028
