跳转到主内容
加入维修社区 - 创建账户
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
MacBook Pro won't start up and makes a tone that repeats?
My MacBook pro was working fine and unexpectedly now will not power up. I have a black screen when the power button is pushed and it makes a single mono tone that repeats until I hold the power button down to power off the computer. It is a 2010 model #A1286. Does anyone have any suggestions? I would appreciate your help. I am traveling in Mexico and nowhere near an apple dealer.
Thanks,
Ken M.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It sounds like your laptop doesn't believe it has any RAM. Try reseating your RAM, then try booting. If it boots you should be good to go, the RAM had become loose in the slot. If you get the same thing then pull one of the RAM chips/sticks, then try booting. Power down and move the installed chip to the other memory slot/bank, then try booting. If it boots through this process you know you have a good chip, in a good slot. If you get the tone you know you either have a bad chip or a bad slot. Continue this process with the other memory stick until you have tested both chips in both slots. This process will tell you if you have a bad RAM chip (that needs replaced) or a bad RAM slot (you will have to live with 1 stick of RAM or get the motherboard repaired/replaced).
这个答案有帮助吗?
得分 5
3条评论:
+1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
完成的
how to overcome this problem
完成的
Same problem in a 17" MBP model A1261. Thanks SO MUCH for the above answer. Looked like one RAM module was not fully inserted in its slot. Not sure at all how that happened, but with teenage boy in house, anything is possible. Took both cards out, put them back in, and voila! Daddy fixed it.
完成的
添加一条评论
i found out if i remove 1 ram chip from my MBP 2010 it starts up fine. i had to go buy an 8GB ram chip to compensate for the loss of a ram slot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jamesmorrow 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 5,348
