跳转到主内容
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
20 个问题 查看全部
When I push the start button, nothing happens (most of the time).
The symptoms: Start-up fails. But a few times I'd get the start-up chime and then nothing. Once or twice I got to log in and then nothing. I noticed, before it died, that while typing and the screen wiggled, the screen contents also wiggled in sync. I took guidance from iFixit, using the "get the hard drive out" series. I needed to retrieve my photo library. Yah, Yah, I know, "why didn't you have it backed up?" I just didn't. I bought a DC-in assembly from you guys and in the meantime got a Universal Drive Adapter (Newertech) from OWC to get the stuff off my drive.
Yesterday I got everything back together, but got the same symptoms. 5 or 6 tries, maybe 1 or 2 chimes. This morning I tried again, got logged in, then nothing.
Does any of this ring any bells?
Thanks in advance.... J Aronson
I tried reseating my RAM to no avail, but thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
11条评论
have you tried reseating your ram?
完成的
I don't know how to answer responders
完成的
OK, now I get it. pollyintop, tx. No luck with the reseat.
完成的
pollyintop. tx...where to find the forums you mentioned?
完成的
lemerise... tx....is it possible to fix w/o $280 logic board?
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
Looks like a failing graphic chip so the logic board would have to be replaced. No problem with your data, just remove the hard disk and put it in an IDE external enclosure or in another PPC machine.
这个答案有帮助吗?
得分 5
2条评论:
there are a couple of forums with "fixes" for this issue including making a shim from foil to push the graphic's chip onto the board better. I also had this kind of issue with a bad start and it was the charger at fault (no screen wobbles though)
完成的
@pollytintop : the problem is << I noticed, before it died, that while typing and the screen wiggled, the screen contents also wiggled in sync>> clearly a symptom of a desoldered graphic chip on theses G3s associated with the freezing and difficulty to boot the system.
完成的
添加一条评论
FYI.... http://www.applefritter.com/node/10193
http://blog.mic-b.com/?p=199
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
johnaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 520
