跳转到主内容
Patagonia outerwear that keeps you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
136 个问题 查看全部
R1 jacket pocket delaminate
The bottom lamination of the pocket of my R1 fleece has released causing the pocket to basically be useless. I don’t want to stitch it because the jacket is only one layer so it will show on the outside. Does anyone have advice on how to re-adhere the pocket and even add more durability to the rest as I’m sure this will continue to fall apart.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I'd give this Gorilla product a shot:
https://www.amazon.com/Gorilla-Waterproo...
这个答案有帮助吗?
得分 0
添加一条评论
Glue is a good solution although I use a product called Goop. You have to use care when using any glue because it gets messy. If you want a clean professional look learn how to sew a “hidden switch”-google it. It’s the stitch used to hem pants legs on a suit
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 65
