constant dripping into the washer tub
I have same problem. After wash cycle finishes if I do not remove cloths immediatly they become saturated with water due to the constant dripping into the washer tub. I put a dry towel in there to see how significant the drip was and forgot it till the next day when I found it dripping wet. I also notice my water bill higher. I checked everywhere for leak, drip, running toilet ETC... but only found it to be the washer
Lucinda Robayo what is your washer make and exact model number? Your washers issue appears leaking water inlet valves
由 oldturkey03 完成的
