跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Charger blew but the board looks OK- how can I be sure?
My macbook was out of battery so i went to charge it.
My charger blew (popped, bang, adapter broke up) so I replaced it with a brand new 85w magsafe charger.
The charger cable connection light wont come on to indicating its charging BUT the laptop screen still comes up with the empty battery/needs charging graphic suggesting the laptop is still ok.
I've opened it up and I can't see anything black or blown up.
Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
no light on the magsafe would indicate a dc-in board or mainboard issue
这个答案有帮助吗?
得分 4
添加一条评论
@Adam Pritchard - how about installing this gem of an app to look deeper into your batteries health and your charger CoconutBattery post a snapshot of the main window here for us to see.
这个答案有帮助吗?
得分 3
3条评论:
@dan it's shut me out again so can't install anything
完成的
@Adam Pritchard - Then your battery is fully discharged 😞
You’ll need to replace the MacBook Pro 15" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board to hopefully get the MagSafe charger to charge your system. Otherwise you’ll need to inspect the logic board for burnt or damaged components. At that point you may need to get your system to someone who has deeper skills.
完成的
@danj You're a star for the link Dan, I'll give that a try. Thank you
完成的
添加一条评论
I'd check around the charging connector for blown components like fuses etc.
这个答案有帮助吗?
得分 0
1条评论:
Thanks both.
I have tried an SMC reset ("Shift-Control-Option on the left-hand side keyboard and the power button simultaneously for 10 seconds")
And the power momentarily returns - enough to see what apps etc I had open. Lasts about 20 seconds then switches off.
Battery % indicator does suggest 20% battery still (tho I think this might be faulty itself)
完成的
添加一条评论
添加你的答案
Adam Pritchard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 69
