跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Flashing question mark folder on boot up
I was gifted a Mac Mini model A1347, I believe its a late 2014 model. 2.6GHz Intel Core i5 with 8gb of LPDDR3. I was told the Mac has only been used a handful of times since its been purchased. When I tried to boot, I got a flashing ? folder, and after research I've found that this is most likely because the mac no longer has a working operating system. I'm not familiar with Apple products at all, so I'm wondering what my next course of action should be. Attempt to boot from a USB with a current OS? Would Geek Squad possibly still work on it even though its outdated? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If you have another Mac: https://macdaddy.io/install-disk-creator...
Download Your Desired MacOS (I recommend 10.14 Mojave) and Follow they're guide...
Otherwise Hold Down: https://support.apple.com/en-us/HT204904
When In MacOS recovery, Go to Disk Utility, Check for a Partition that could have MacOS.
If there isn't one, Try Partitioning it to MacOS Extended (Journaled). Then try to install MacOS.
IF THAT DOESN'T WORK, It's likely A failed Hard Drive/SSD.
Part: OWC Aura Pro X2 SSD or [关联产品丢失或禁用: IF107-098] or [关联产品丢失或禁用: IF107-142]
Guide: Mac mini 2014 年末机型的硬盘更换 or 2014年末款 Mac Mini 固态硬盘替换
Replace or upgrade the PCIe solid-state drive in a variety of Macs.图片
产品
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 固态硬盘图片
指南
难度:
中等
15 minutes
Mac mini Late 2014 硬盘图片
指南
难度:
中等
30 minutes - 2 hours
这个答案有帮助吗?
得分 2
添加一条评论
Lucky for you there's an entire page on this exact issue. It's for MacBook, but the concept is largely the same.
As a former Geek I can say with confidence, Geek Squad would also still work on this if you decide to go down this route. Although it's usually a pretty straight forward. Bear in mind your options may be somewhat limited depending on what they find. If it's a hardware issue, that isn't something they can take care of in store.
这个答案有帮助吗?
得分 1
1条评论:
@flannelist - You Beat me to it! :-)
完成的
添加一条评论
添加你的答案
Christian Berent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 16
总计 468
