跳转到主内容
What is this thin black layer under the keyboard, is it important?
When attemprintg to redo the thermal paste on an early 2011 macbook pro 13", I was having great difficulty removing the logic board as it seemed to be stuck on something underneeth it. After much gentle wiggling I finally got it off but have ripped a hole in the thin black material that goes above the logic board and is just underneeth the keyboard. The inside of the hole is still stuck onto the heatsink, so should line back up when reassembling the laptop.
What is this material and what does it do? Does it need to be replaced because I broke it? Can I just tape it back on? Where can I find a replacement part?
Thank you very much for any help :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It's not important for the functionality of the Mac. It's there for a few reasons. It's likely used for shielding from electromagnetic interference. But it also serves as a barrier between the keyboard and the interior of the device. At least on newer MacBooks, there is nothing else to prevent liquid or substances from the outside from getting into the Mac through the keyboard.
You could patch it up if you like but it probably won't have an appreciable impact on the way the device operates or it's performance.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much, I really appreciate the info as I couldn't find anything online. Thank you! :)
完成的
添加一条评论
@thecheeseguy5 & @flannelist - This sheet is also the keyboard backlight light spreader. There are three LEDs in the string mounted within it. The backlight sheet is the right most cable in the set of three at the bottom.
The backlight sheet can be replaced MacBook Pro 13" Keyboard Backlight Sheet, Sunrex
这个答案有帮助吗?
得分 1
2条评论:
You know, I didn't even think about that since that's not the case with any of the Macs I typically work on. I'll be the first to admit, Unibody Macs are not my specific expertise. Still not integral to function, but inconvenient to live without if the LED string was damaged. The back light might be inconsistent in that spot, but otherwise probably fine.
完成的
@flannelist - I just wanted to fill-in this detail. The LEDs are not near the tear. But being severed only interferes with the backlight of some of the keys.
It still will work in this state ✌🏻
完成的
添加一条评论
添加你的答案
thecheeseguy5 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 103
