跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
trying to replace case on nintendo switch joy cons
so long story short im trying to replace the casing on a set of joy cons and the casing that i bought... doesn't have a instruction manual in the box ._.
the rear casing won't come off after unscrewing all the screws also
help???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
https://www.youtube.com/watch?v=ymBbKWzL...
这个答案有帮助吗?
得分 1
添加一条评论
Hello. I believe that the ifixit guide for joy cons might help. They explain how to take them apart and disassemble it.
Just use the part where they talk about joycons
任天堂 Switch 拆解
这个答案有帮助吗?
得分 1
添加一条评论
Did you remove the rails before you took out the screws? The back plastic should come off relatively easily.
Be sure to open it like a book with the part that slides into the switch as the books spine.
Check out this guide for how to get into the case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 222
