跳转到主内容
加入维修社区 - 创建账户
LG 27 英寸 UltraFine 5K IPS 显示器,兼容 macOS 系统
I can't open monitor back cover
Could you help with instruction how to open monitor back cover - I can't understand how to do it? I already have been removed 4 screws, but how to find clips and what to do next I can't understand.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
the back usually doesn't come off on monitors.
the typical teardown is done by removing the screws (which you've done) and then carefully prying the bezel cover away from the display from the front of the monitor.
这个答案有帮助吗?
得分 1
2条评论:
I have a feeling that I need to do something with clips, etc. Because I can't remove easily cover :(
由完成的
hm. when I took my monitor apart I had to use some force to get the clips off because they are held on fairly tight
由完成的
添加一条评论
添加你的答案
Ihor Syrota 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 1,298
