跳转到主内容
No LCD backlight after replacing inductor
About a month ago I had to replace a missing inductor (L9004) on my early 2011 MacBook pro. I just got them in the mail today and successfully soldered the inductor. The screen now turns on, however now I have no backlight on the LCD. I know the screen itself isn't the issue and I'm unsure what to look for on the motherboard. For all I know I could've damaged something when I was using the heat gun. I'm still relatively new to all this stuff. If somebody could give me some tips on what to look for or test that would be great!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
your problem is more than likely that your backlight cable was damaged during the process of replacing said part
这个答案有帮助吗?
得分 0
2条评论:
I had the display removed from the laptop when I was doing the repair so that eliminates the display cable. Do you have any other ideas?
完成的
try re connecting the cable. its possible debris got in between the backlight connection
完成的
添加一条评论
添加你的答案
Chase Simering 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 88
