跳转到主内容
任天堂最新的混合型游戏机,于2017年首次发布,Lite和OLED型号分别于2019年和2021年跟进。Switch兼具家用和掌上游戏机的功能。
1180 个问题 查看全部
How to fix a switch charging port
can i fix a switch charging port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
There are hundreds of YouTube videos on replacing a switch charging port. If you have a hot air station and are confident in soldering it’s pretty easy. If not find a computer or mobile repair shop who can do it for you.
这个答案有帮助吗?
得分 2
添加一条评论
It's doable for an experienced technician, but it's not the port to learn on. Switch ports have a double row of pins, the inner row can't be seen. If you've already done other "big clunky charge ports" on other boards then a switch is a reasonable next step. If you're a beginner, start with an easier port like xbox hdmi.
这个答案有帮助吗?
得分 1
添加一条评论
Unscrew or pry the device's rear cover off. Then locate the USB charging port. Then place your new USB port in the old one by taking the old port off. Then place the back cover back on, then turn it on. You will be happy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Konopka 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 39
总计 1,356
