跳转到主内容
加入维修社区 - 创建账户
The Dell Inspiron 15 3558, part of the 3000 series, is a 15.6 inch desktop-replacement laptop with solid specs, plenty of storage, and long battery life.
Dell 3358 won't boot-hard drive is good
I'm a little bit dissapointed, this morning I wanted to start my laptop but I got a "no boot device found" error. I set my HDD to #1 in the BIOS setup boot sequence. I went into diagnostics and the hard drive tested as good. The last time the system was used it booted fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Did you know what the fix was? I was trying to boot from "Internal HDD" but it turns out you had to boot from "Toshiba [model number]" in UEFI boot.
这个答案有帮助吗?
得分 0
1条评论:
Maybe bad BIOS settings or a bug? Reset it to factory defaults and reconfigure it. See if Dell has a BIOS update available.
完成的
添加一条评论
最有帮助的答案
In some cases, it can be due to how the boot order is laid out as some of these laptops require the user to explicitly pick the hard drive, not just an "Internal HDD" group where it should in practice search for you. If that happens, reset the BIOS settings to default and see if it remains. If it does, there may be a bug with the BIOS or a quirk of the drive used in the laptop with the BIOS.
If not, is it on the original drive? A lot of these Dells have Seagate drives, which happens a lot due to their tendency to silently fail without warning. While it can sometimes be fixed by reinstalling Windows (and isn't a BIOS setting issue), it tends to be a bad hard drive in many cases. In addition to that, it's in a spot where it can be easily damaged by vibration which doesn't do anyone favors. The bad placement makes it a candidate for an SSD -- placing it by the palmrest where people slam them down first is ASKING for trouble.
Try to reinstall Windows, otherwise, the hard drive failed. This one isn't hard, and shouldn't take more than 15 minutes: Dell service manual
这个答案有帮助吗?
得分 1
1条评论:
I installed Ubuntu Linux and now it works perfect after a new OS. I just had to change the boot mode from Legacy to UEFI and it works, even Windows still works (I now have to load into Windows from the HDD model number in the boot menu)
完成的
添加一条评论
添加你的答案
80stechkid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 759
