Seagate Business NAS acting abnormally
I have just acquired a Seagate Business NAS 2 bay. It didn't have the original power supply, so I bought one from Amazon. It seems to work normally, but I'm unable to turn the unit off via regular methods. I connected it to my network and downloaded the requisite software. The software found it, and I can access the maintenance page via IP address in my browser. It even found the hard drives I put in there.
The problem is I'm unable to factory reset it so I can make use of all functionality. I followed the instructions in the manual and it refuses to reset. Is there anything else I can do to make this work?
@enron_hubbard how did you try to reset this? Which one of these steps does not work for your device https://www.seagate.com/manuals/network-...
Flashkey? Interesting. Probably has the NAS-OS on it to reboot and reset. https://www.seagate.com/support/kb/busin...
See what you can get from here https://www.seagate.com/support/external...
由 oldturkey03 完成的
When it was on, I held down the reset button in back. First for 5 seconds, then 10,then 15. The manual stated the light would flash, but none of that happened.
由 Jay Davidovich 完成的
@enron_hubbard Used the paper clip yet :-) ?
由 oldturkey03 完成的
@oldturkey03 Is there another reset hole that only a paper clip can fit in? I was able to poke the button with a pen.
@oldturkey03 This thing refuses to turn off or reboot. Short press, long press, this thing just stays on. Is there a USB key I can make to automatically load NAS OS?
显示更多的4条评论
