跳转到主内容
加入维修社区 - 创建账户
2019 年 7 月发布的 8 英寸平板电脑。有 32GB 和 64GB 两种型号。屏幕采用 TFT LCD,分辨率为 800 x 1280 像素。主摄像头为 800 万像素,前置摄像头为 200 万像素。版本包括:SM-T290(Wi-Fi 版);SM-T295(LTE 版)
My internet doesn't work
The wi-fi on my tablet doesn't work properly, there are certain places in my home where the wi-fi doesn't work, and places that do, and that's just on my device my family's devices work properly.
I wanted help with this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @vini13
Try using the tablet's WiFi as close as possible to the network router in your premises i.e. <10cm and check if it works OK and that it maintains a stable connection.
If it works OK it may be a loose WiFi antenna connection that is the problem, (supplier example only to show what the antenna looks like)
Here's a teardown video for the tablet that may help.
The antenna can be seen being removed from the tablet at ~1:51 minutes into the video.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vinicius 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 24
总计 260
