跳转到主内容
加入维修社区 - 创建账户
蘋果2020年的主流 iPhone 機型,發布於10月23日,搭載6.1吋 OLED 螢幕及12MP 雙鏡頭模組,有著5種顏色。該機型為 iPhone 11的後繼產品。
Stuck Lock Button after drop
I fell and dropped my iPhone 12. It was in a secure case, but when I picked it up I realized that the lock button was stuck and it would no longer lock. The area around the lock button is SLIGHTLY bent, not too bad, but slightly. However, there are no cracks on the phone and it is working well besides the lock button. Is there any way to fix this issue? I have been using assistive touch, but I would love for my button to work again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Lock button? You mean power button? Also why are you using assistive touch? Sorry but I’m confused.
完成的
Yes, sorry I mean my power button. I’m using assistive touch to lock my iPhone since I can’t use the button.
完成的
Do you know how to open a phone?
完成的
添加一条评论
1个答案
最有帮助的答案
It's definitely possible to try to fix this. but you'll need to get the phone open to do so. if the housing is the problem it may require swapping the housing to one that's free of bend depending on how significant the bend is.
Word of warning, the 12 series is a bit of a bear to get open due to the strength of the adhesive holding the screen in so you'll need a fair amount of targeted heat. And a lot of patience. You'll need to remove the battery and the logic board to get at the power button mechanism. You can see if you can bend the housing back out from the inside. Or at least make sure the power button itself it seated correctly.
Be aware if you have a 5G variant of the iPhone 12, there is an antenna soldered to the bottom of the logic board which goes up and around the battery which is really the only reason the board would need to come out since the antenna covers the screws necessary to get at the button. There isn't an iFixit Guide for either of these, but using the other Guides for reference is usually my tactic for handling this.
Some pictures of the damage may also help determine the best course of action since we don't know exactly what sort of bend you're dealing with.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Leslie M 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 35
总计 1,713
