跳转到主内容
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
93 个问题 查看全部
Screen burn/ghost images on dark backgrounds.
Hi all, I've had a panicked message this morning from a customer. She had purchased a used iPhone 13 and has noticed that she can see "someone else's apps behind her screen". She forwarded a video but it's hard to make out.
When the screen is dark (not off) she can see faint app icons "behind her apps". I'm thinking screen burn but she is concerned that there is some sort of virus or malware.
Unsure of device age and previous usage as I haven't seen the phone yet.
Any advice would be greatly appreciated
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
At the moment I think it’s safe to assume that it’s not malware, malware usually does much worse thing and malware is very rare on iPhones
Also burn in is quite uncommon on iPhones that have Original displays,more common on 3rd party displays but still quite uncommon
what I think the issue is most likely to be is a dislodged display connector
It could also be debris but I have seen this happen on iPhones and iPods when the ether the display is damaged, connector isn’t seated properly or the connection has debris and needs cleaned with isopropyl alcohol
Might be worth trying the above before replacing the anything ,it’s entirely up to you:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
4条评论:
Hi, after seeing the device I confirmed it was burn in for my customer.
Her initial message made it sound like she could see another, fully working set of apps behind her own when viewing on a dark background.
Upon inspection it was only 2 app icons (telegram and Viber) that were present and in the same location while using the device in various iOS functions.
Thanks for your help
完成的
@dangerw1ll
Your most welcome
Glad you got it all sorted out:-)
完成的
@dangerw1ll must’ve been a bargain basement screen was it? I’ve replaced phone screens for years and not seen one iphone with screen burn, only dreaded Samsung.
完成的
@strongbow
that’s exactly what I was thinking ,iv never seen it on a iPhone ,only ever Samsungs
完成的
添加一条评论
添加你的答案
iRepair 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 29
总计 477
