Video only responsive when plugged into external monitor
When the laptop boots without external display, it is completely responsive for about 2-6 seconds on the login screen, and then the display completely freezes (not black, freezes). Brightness controls still work, and certain keys do produce an error noise from the speakers when held, which leads me to believe that the computer itself is still functioning behind the frozen display.
When booting with an external monitor, the laptop works perfectly and mirrors the external display on the internal display perfectly, but will freeze within the same 2-6 second time frame after being unplugged from HDMI. Plugging the HDMI in after this freeze does not fix the issue.
Safe mode (holding Shift on startup) DOES NOT exhibit the same behavior, everything works as expected with no issues at all in safe mode, even when not plugged into an external monitor.
Any advice on what to do here is greatly appreciated.
Troubleshooting steps taken (all failed to change behavior):
- Turning off FileVault
- Reset SMC
- Reset NVRAM/PRAM
- OS reinstall (Catalina)
- Factory reset
- OS upgrade (Monterrey)
- New user admin account
- Disk Utility first aid
- GSX2 MRI diagnostics (came back with 0 issues found)
6条评论
@sville2000 both the internal and external monitor freeze up on you?
由 oldturkey03 完成的
Nope, just internal. Works perfectly when using external monitor. It only freezes when the only screen in use is the internal.
由 Anthony 完成的
@sville2000 thank you for clarifying that for me. The internal display works normal is safe mode?
由 oldturkey03 完成的
@oldturkey03 That's correct, in safe mode, the internal display works 100% as expected
由 Anthony 完成的
@sville2000 just one more question for my own research. With an external monitor attached, the internal monitor works normal at all times and in all modes?
由 oldturkey03 完成的
显示更多的1条评论
