跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
Why do all my controllers drift only to the left
I've used three of these controllers now and all three left analogs drift only to the left of the screen. Is it the same for everyone? Do these controllers only drift to the left once they do start drifting? I'm wondering if it's something specific I'm doing or if I could possibly prevent it. I majorly play Fifa, Ratchet, GoW, Wolfenstein.
Regarding the drift itself, I've opened them up and cleaned them several times. I'd appreciate any other suggestions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Unfortunately this has been a common issue for joysticks since they were first introduced in controllers. The PS5 controller uses the same old potentiometer joystick as prior generations, which wears out quickly and can get dust in the sensor, which causes the drift you are seeing. The only way to fix it permanently is to find a joystick that doesn’t use potentiometers to detect your input. I would check out the King Kong Pro 2, which uses a electromagnetic joystick.
https://www.amazon.com/KingKong-Wireless...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oluwaseyi Sule 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 46
过去 30 天: 146
总计 5,146
