跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Why wont this iPod touch 4th gen power up?
Okay so i normally fix ipod 2nd and 3rd gens and thought i would give a 4th gen ago.
Iam replacing a digitizer +screen which are both connected, during removal i broke the wifi antenna cable.
I then continued to follow the instruction following every step making sure that i wouldn't brake anymore ribbon cables.
I believe that i have NOT broken any other cables but the ipod will not power on ?
Could anyone help me with this would the broken wifi antenna result in the unit not powering on ?
Any help would be greatly appreciated
Update
Thanks guys , turns out that when i but the logic board back down the lcd was coming loose without me realising , pretty silly to be honest but thanks for the responses :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Jack, sounds like you got it going again. All you have left now is to accept the answer that helped the most. It's the only pay we volunteers get :-)
完成的
添加一条评论
2个答案
已选择的解决方案
Plug the iPod in to the AC adapter and give it about 10 min, you should then see the charge indicator come up.
Some USB ports don't carry enough charge to juice up an iPod with a drained battery.
这个答案有帮助吗?
得分 3
添加一条评论
Don't mean to belittle at all, but just to make sure - Are you not getting a sync? The LCD connector is a bit of a pain and can appear to be in place when it's really just wedged in an odd position. Perhaps you began the repair on a very low battery and we are simply getting no power.
Also watch as the digitizer cable if not folded over on itself can become easily damaged.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for responding quickly :)
but no i started the repair at nearly full battery, but i don't get any response when i plug the unit in no vibration no noise no response from my mac.
okay ive just taken it apart again to see whether i did anything wrong also im adding a small metal contact piece which i seen from other questions that leads to problems.
完成的
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 3,110
