跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
Trackpad or Touch Pad not working
My trackpad is stiff. It is very difficult to click on something. The lower left corner works when tapping and holding down the control key to say, empty the trash or eject a thumb drive. But clicking not so much.
I read here that I should check the battery for swelling. That interests me because also with the touchpad not working, my laptop does not sit flat on the desk. It has a wobble to it. Could the battery be swelling causing the laptop to wobble and restrict the touchpad/trackpad?
If it is swelling then replacing the battery would be the answer correct?
Thanks much.....
Rich
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m suspecting your battery which is under the trackpad has swollen up enough to stop the trackpad to depress. Given the age of your system it also tells me you are in need of a new battery anyways. Most battery’s last around 4~5 years at most.
Here’s the needed part MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery and here’s the guide 2013 年末期带Retina显示屏 MacBook Pro 15" 电池更换
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery图片
产品
$89.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rich Baranski 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 29
