跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
After battery replacement, iPhone does not boot, nothing on screen
Hey there,
I did a battery replacement following iFixit guide. Unfortunately, the adhesive was super strong. I used a guitar string like suggested in the guide.
In the image they only use the floss from one side, I used the guitar string from both sides.
I reassembled everything, but phone wont turn on. Backlight is on, sometimes I can see apple logo.
I noticed some flex cables on the top side (where floss is not used!) which have some silver scratches. Is it possible that I broke these flex cables?
One goes to the vibrator siwtch and volume controls, the other one I am not sure?
Connecting to a mac finder only says "There is a problem with the iPhone “iPhone” that requires it to be updated or restored."
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
@magnusja Could you take a good quality and up close picture of the suspected damage? A damage to those flex cables could definitely be a cause issues. Adding images to existing questions.
完成的
Meh, looks to me like a little bit of paint got scraped off the flex cable. My best guess would be to vote that it's okay. The FPC connectors look pretty good too.
完成的
@magnusja As @dadibrokeit said, looks like a scrape and not terminal damage. The only other thing I can think of is as @imicrosoldering explained, you have been unfortunate and caused long screw damage :(
完成的
Sorry for the delay. I added some pictures of the screw hole (not sure if you can see anything, let me know if you need better pictures).
What strikes me as odd is that I did not screw anything back together. I plugged in the new battery, then the display and it wouldn't turn on. No screws.
Thanks a lot helping me debug this issue!
完成的
显示更多的1条评论
添加一条评论
2个答案
最有帮助的答案
What you have described sounds like what we call long screw damage where the wrong size screw has been inserted in the shield that covers the LCD connectors. If you can, take and post a close-up pic of the screw hole in the red square.
这个答案有帮助吗?
得分 2
2条评论:
I used a proper camera to capture the hole, but not sure if you can recognize anything on the pictures.
This strikes me as odd because I did not screw anything back together yet. So this must have happened when unscrewing. I switched the display a couple of times. Could it be that I screwed in the wrong screw already ages ago and it just now destroyed the logic board after unscrewing again?
完成的
@magnusja It’s not very easy to tell from the pictures (LSD can be hard to get proper on screen without a microscope), but as @dadibrokeit says above, I’d also probably stop worrying about LSD. I’ve never had LSD damage happen over time, it’s either there or it’s not.
One thing I’ve noticed (though very slightly) is the top liquid indicator kinda shows a hint of moisture detection. That could be something to check, any of the other indicators show something?
完成的
添加一条评论
The top flex is the power flex which if you used a metal guitar string could have been damaged. I’d leave the battery unglued and buy a new power flex and fit it. Test it with the battery unstuck and if everything is ok, stick it back in with adhesive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Magnus Jahnen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 80
