跳转到主内容
iPhone 13 front camera replacement walkthrough
I have an iPhone 13 with a damaged front camera. I haven't been able to find anyone that has done this replacement and I haven't worked on any 13's yet.
It looks like it's a fairly straight forward swap with the caveat that face ID won't work without some soldering being done. TBH I'm fine without having face ID.
Can anyone confirm that it's a simple part swap?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
might be of some help if its the correct camera. https://www.youtube.com/watch?v=BSH1cy1F...
这个答案有帮助吗?
得分 1
1条评论:
Perfect. That's a Pro, but I'm sure it's similar for the 13.
完成的
添加一条评论
Hi Bill,
I did find a guide on a Spanish site; it's got an option for the English language, but it didn't seem to work well until I allowed Chrome to autotranslate, and after that it seemed to be usable.
Manuals / Apple iPhone 13 / Front cameras
I can't be sure about the iPhone 13, but on the 11 Pro at least, you can replace just the camera without losing Face ID. It involves taking a Dremel to the metal housing and digging out the camera, leaving the dot projector and IR camera in place. You can get the general idea from viewing the iPhone 11 Pro guide that I helped out on.
iPhone 11 Pro Front Camera Replacement Without Losing Face ID - iFixit Repair Guide
I was looking at the same situation on an iPhone X and was able to find a site that sold just the camera alone without the rest of the front camera assembly, along with a replacement metal bracket that could be used if you decide to just destroy the old one in the process of disassembling it. Turned out to be the IR camera that was causing the problems so I didn't end up doing the repair, but same logic applies; use your specific guide to get the camera out, then use the same technique to remove the camera from the assembly.
Good luck; let us know how it goes! Take pictures; it would be great if you authored a new guide to that replacement for all the other people who are going to run into the same problem. It's actually pretty easy to do, and there's plenty of people, myself included, who will be happy to help you with it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bill Shannon 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 110
总计 1,309
