跳转到主内容
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
20 个问题 查看全部
PS Button and parts of the D-Pad not working
Hi! So, I recently wanted to boot up my PS4 again and play some games with a friend... but then the controllers wouldn't turn on. I tried connecting them to my PC - they worked but when I connected them to the PS4 they refused to work with it.
I thought it's battery issues so I left them to charge and afterwards they wouldn't work yet again. I opened them and saw nothing wrong... and then it hit me. The issue is the PS / Power button.
I connected the controllers back to my PC, installed DS4Windows, mapped all buttons to keyboard keys and opened a key logger. Everything except some of the D-Pad buttons and the power buttons worked.
Now, the buttons themselves seem completely fine. There's no visible issues. Can it be the little transparent / green plastic thing that stays under the buttons? If it is, can I replace it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Whoa, this was back in December?
Anyways, I ordered two replacement membranes and swapped them. This fixed one of the controllers, however I &&^&@@ up the ribbon cable for the USB of the other one so I can't really confirm if it fixed it.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Check the black parts on the clear rubber for the buttons are clean. Also clean the contacts on the board with an eraser then try it.
这个答案有帮助吗?
得分 1
5条评论:
Hey, sorry for the late reply.
Can you be more clear about what you mean by "clean the contacts on the board"?
完成的
@uskizzik on the flex where the buttons are. There are some contacts where the buttons sit above.
完成的
So the black parts right below the buttons? Clean them with an eraser? Like... a pencil eraser?
完成的
@uskizzik yes but gently. You’ll see the film with the contacts I’m talking about in step 7 on this.
How to Fix PS4 Controller Analog Drift (R3 or L3 not working)
完成的
@strongbow Didn't seem to improve at all...
完成的
添加一条评论
unfortunately this is an indication that the Flex Ribbon Connector is starting to wear, this is either a simple fix with some 99% ISO Alcohol and a cotton tip to clean where the Circuit board meets the Ribbon or a replacement ribbon entirly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
uSkizzik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 614
