简介
This is a guide for a Sony DualShock 4 PlayStation 4 Controller and can be used on any other companies’ controllers (Scuf or Custom Controllers).
This procedure will help fix an R3 or L3 button on a controller that is not working properly or is having issues when trying to move.
Take care during this whole operation as these are very small and sensitive parts, but be very careful in Steps 1 and 2 to not damage any wires that connect the controller and the battery, as well as while reassembling.
你所需要的
Remove the four screws from the back of your controller using a Phillips #0 screwdriver.
Separate the front and the back of the controller.
47等其他人完成本指南。
5条评论
Thank you for this!! So many great pictures!! :D
The drift for me also prevented or interrupted movement with the left analog stick. Menus would continue to scroll after i scrolled them or wouldn’t move my character on screen.
Nach Wechsel der Potis hatte mein Controller Drift an beiden Achsen. Das liegt daran, dass die Potis nicht 100% mit denen der Werkskalibrierten übereinstimmen. Eine nachträgliche Kalibrierung ist leider nicht so einfach möglich, da die Korrekturdaten im EEPROM des Controllers gespeichert sind. Deshalb habe ich parallel zu den Potis je einen 2MOhm Poti gelötet, mit denen der Spannungsoffset kompensiert werden kann. Ergebnis: Keine Drift mehr. Die Controller arbeiten wieder einwandfrei.
Great walkthrough and high-res images makes the job a lot smoother. Only remark I have are three things: 1) There are four clips that are hard to see on the images, and aren’t detailed; they are on the top right and left, under the “SHARE” and “OPTIONS” buttons, as well as the two clips on either side of the docking port. These easily break, although I avoided that. 2) The sensor housing have very fragile clips which easily break after a repair or two. DO NOT USE FORCE ON THESE! If you’re in doubt, just try and blow some air into them. Some remaining dirt is better than a broken stick. I also avoided this thanks to a comment on the step, but I’ve heard many has broken their sensors doing this. 3) The USB connector isn’t labeled as a pull-out connector. This isn’t much of an issue, but in sub-par lit environments, it looks like a clip connector. Have some friends ruining their USB ports due to ripping the connector off the PCB, thinking it’s a clip connector.
tidak membantu sama sekali seperti padi yang terbanjiri dan tidak bisa di proses untuk menjadi nasi lalu di nikmati
