跳转到主内容
Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。
256 个问题 查看全部
Steam Deck fit toghether case parts
Hello everybody, I have a Steam Deck, where it seems that the front case and the back case doesn't fit perfectly together. This result in a clicking noise on the right side of the steam deck when holding it very tightly. The case doest seem to be very sturdy.
As the official support cannot offer help as its not a functionality issue I would like to repair it myself.
On what part cases do I have to focus when trying to fix that kind of problem. The spacers or isolation material?
Thanks you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
Here’s a full disassembly guide of the steam deck
更换 Steam Deck 前面板
As for what you should focus on ,I think it’s probably best to look into the shell/case as they have everything screw into them
If you follow the guide through and successfully reassemble the device you should hopefully have a steam deck that fits nicely together
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
4条评论:
Thank you very much for your kind reply.
Unfortunately for me, it's too challenging removing the whole front panel.
But I was able to remove the back panel and reinstalled it. Now it seems a lot better. During gameplay when the device is heating up the parts still feels a little bit uneven but in cold state its way better than before.
Thank you very much
完成的
@fhihu
Glad to hear it’s somewhat improved:-)
If it gets worse asking valve(again) might be a option
完成的
Hello, MacOS,
This guy wrote in his review that the backplate doesnt fit nicely at his steam deck.
Steam Deck Back Plate
Maybe it only the backplate. If its getting worse I will contact steam support again.
Thank you
完成的
@fhihu
It could be that the back plate is designed in such a way thats it’s difficult to get on and off
The person mentioned using electronics grease to help get it on properly
Doing something similar might be a option if it becomes a issue
It could also be worth looking for a 3rd party replacement part ,if you do this look at the reviews and check to see if people as saying anything similar:-)
完成的
添加一条评论
添加你的答案
benji wankerman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 277
