跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Strange screen issue depending on the brightness
Hi.
I just bought a Galaxy Note 3, and seems to have an issue, basically, if the brightness is not on max, it shows this strange static on the screen.
Sometimes it doesn't show, but that seems to be rare.
Could this be a flex cable issue?
Thanks
Update 12/28/2022
Unfortunately, the screen is all black now, it started as a few purple spots to a completely non-functional screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @overflowunt
It may be a display problem.
Does it do this when the charger is connected?
Try using the phone in safe mode and check if the problem occurs.
If it doesn't then a downloaded app may be the cause of the problem. The trick is to find out which one.
Also try mirroring the screen and check the display on the external display. If it is OK then it seems like the problem is related to the display.
Here's the ifixit 三星盖乐世 Note 3 显示组件更换 guide that may help.
这个答案有帮助吗?
得分 1
3条评论:
I installed a custom ROM and it still shows, I'll try to mirror the display and see if it shows on the external display or not.
完成的
If you say it’s rare which I’d take as intermittent then I’d take the back off and check the cables for the screen etc are all seated correctly.
完成的
I tried recording and using TeamViewer and it doesn't show on any of them.
I opened the phone and I may be wrong but are these (they look like resistors?) on the board burned?
https://snipboard.io/RX0din.jpg
I tried cleaning with etylic alcohol but it didn't help.
The phone screen also appears to have this yellow spot at the edge.
https://snipboard.io/3WukC2.jpg
完成的
添加一条评论
添加你的答案
OverFlowUnT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 169
