跳转到主内容
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
103 个问题 查看全部
Do I need a new screen only or are there other problems?
My daughter dropped her A2179 MacBook Air and her screen now has lines that have gotten progressively worse but it appears the progression as stopped as you see them now in this video:
https://youtube.com/shorts/FiWDU1wiCb4?f...
There are no visible cracks in the screen. Is it likely that the screen is my only problem and a replacement will fix the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Brent,
Yeah, that's definitely a cracked LCD panel. I would have a high degree of confidence that replacing the screen will fix it.
Keep in mind that the MacBook displays are non-repairable (at least not for us home DIY-ers) - you can't just replace the LCD panel separately from the digitizer, for instance; you have to replace the entire display assembly.
MacBook Air 13" Early 2020 Display Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brent Fidler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 68
