简介
使用本指南更换 2020 年初 MacBook Air 的显示屏。
你所需要的
如果你的 MacBook 运行的是 Big Sur v11.1 或更高版本,则禁用自动启动可能不起作用。你可以正常进行,但请确保在你进入后立即断开电池连接。
使用 P5 螺丝刀卸下以下螺丝:
两颗 7.9 毫米螺丝
两颗 7.1 毫米螺丝
六颗 2.6 毫米螺丝
提起 MacBook 并小心地开始合上显示屏,直到它与上壳成约 90 度角。
保持显示器与外壳成 90 度角,在保持外壳静止的同时笔直向下移动显示器,以便铰链从外壳底部滑出。
取下显示器。
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?查看我们的 [链接|https://www.ifixit.com/Answers/Device/Ma...|论坛] 以获取故障排除帮助。
40等其他人完成本指南。
由衷感谢以下译者:
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
11条评论
Thank you so much for this awesome walkthrough! I can’t believe how much I saved doing this myself. Works beautifully! If I could only suggest a more comprehensive “reassembly” page. There are a couple of missteps I made (eg. trying to install the antenna bar and accidentally leaving the display cable connector under it) that would have helped. In any event, thank you so much!
Thanks for the tip! I’ve added a reminder to that step.
when starting the process of installation, make sure that at least the inside hinge screw is installed and mostly tightened. once the antenna is installed, there is almost no room for that screw to be inserted without a tight scrape against the end of the antenna. a very tight fit. i sometimes only install one hinge screw, usually the center ones, and then align the lid before adding the others and tightening everything up. in this case, would save you some concern to address this beforehand.
Definitely not. Also, there is no such thing, perhaps you meant 2020? Also no.
