跳转到主内容
加入维修社区 - 创建账户
Google Pixel 6 的维修及拆解信息。机器型号为 GB7N6 和 G9S9B16。
Pixel 6: Can't use fingerprint after screen replacement.
So I just replaced my Pixel 6's screen via the IFixIt repair kit (btw, this was way easier than expected, so that's a win). However, I can no longer use the fingerprint reader.
If I go to set it up I get an error message: "Can't use fingerprint sensor. Visit a repair provider or g.co/pixel/fingerprintunlock".
That website was seemingly irrelevant and definitely unhelpful :).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 22
2条评论
Can t use fingerprint senor visit a repair provider or g.com pixel
完成的
the Ifixit glue sticky tape is a real son of a ##&&% to get the phone completely sealed. Followed Justin Murtagh's guide and eventually got fingerprint working.
完成的
添加一条评论
10个答案
最有帮助的答案
Ok, so I fixed this. I had to go to this page: https://pixelrepair.withgoogle.com/udfps with my device in fastboot mode (turn it off, then hold down volume and turn it back on).
Installing the software from there and then manually re-starting my device fixed the problem.
However, for the above website to work, I had to use Edge (Chrome would also have worked as they're the same browser under the hood, but Firefox did not work) and I first had to get Google's USB driver from here: https://developer.android.com/studio/run... (unzip this somewhere).
To install the USB driver, put your device into fastboot mode and connect it to your PC. Then open up Device Manager (Win+X=> Device Manager). Right click on your Pixel 6 and click "update driver". Click "Browse my computer for drivers" and point it at wherever you put the driver. The driver should install and then you should be able to go to https://pixelrepair.withgoogle.com/udfps and install the software (don't forget to reboot your phone once it's done).
这个答案有帮助吗?
得分 22
10条评论:
Hi, I have tried this website on both chrome and firefox. I downloaded the USB driver previously from another website by installing it directly in the files but tried in device manager as well and it said 'the best drivers for your device are already installed'. The phone is definitely in fastboot - when I start it while holding the volume down it brings me to a menu and I press the power button to select start. It brings me into the phone, I plug it in (I have tried four different cables), it shows up in the dropdown menu when I select 'connect phone' on my computer but when I click connect, it gives the message 'Unable to connect the phone.'
I would greatly appreciate some advice on the matter as something clearly isn't right.
完成的
go to fastboot mode, then don't press start. leave it with the red triangle, then go to update driver in device manager, it will show the phone with a exclamation mark and will accept the new driver then, then when connecting it won't show "paired" but it will connect... I got past all that, but the software didn't fix my problem regardless.
完成的
worked great, got into fast boot, uploaded the driver in the device manager, ran the tool, and then just had to reboot the phone an additional time after the install. thank you
完成的
Thank you so much man, I usually don't leave comments, but I struggled with this problem for a long time and your instructions helped me fix my phone, thanks !!!!
完成的
Worked perfectly for my Pixel 7, saved me a lot of googling. Thanks very much for taking the time to post your solution!
完成的
显示更多的5条评论
添加一条评论
If anyone else has this problem and the above only partially works (for me it said fingerprint timed out), try restarting in safe mode. Hold power button and up/get to the "power screen" and then hold the power button instead of tapping. Then go to settings and re-register the prints. Worked just fine after that.
这个答案有帮助吗?
得分 7
7条评论:
Worked as a breeze, thanks man!
完成的
This one still didn't work for me. Does anyone else have a suggestion?
完成的
it didnt worked for me
完成的
@robbzinn Remove the reader from the old screen and fit to the new screen. Surprised nobody else has done it. Easy job and works straight away.
完成的
@strongbow I would but it's dead even with the old screen...
完成的
显示更多的2条评论
添加一条评论
yea! it worked! so simple!
这个答案有帮助吗?
得分 2
添加一条评论
Try:
https://www.reddit.com/r/Pixel6/comments...
Same as above, but a little more detailed.
这个答案有帮助吗?
得分 0
添加一条评论
I try all and still don't work. I realized that I have two different connection . Old phone with working fingerprint have 4 dot's on the black belt just next to a fingerprint connection. New one don't have them. I'm wandering if this is the clue. Does someone try to make those four dot's connection by scraping the black belt till you can see copper connection. When you look on the back side off fingerprint you can also see a connector .
这个答案有帮助吗?
得分 0
添加一条评论
Google pixel 6a fingerprint is not working
这个答案有帮助吗?
得分 0
添加一条评论
In my case the technician uninstalled the screen and reinstalled it twice more and then fingerprint scanner worked again.
(I did drop and crack my screen a week after again ...though now haven't had it repaired since ..because if I do either I drop not again or someone will steal it ...a cracked screen is the best antitheft )
这个答案有帮助吗?
得分 0
添加一条评论
After changing the folder finger print is not working
这个答案有帮助吗?
得分 0
添加一条评论
Uninstall and reinstall.. when that was issue with mine the technician tried two more times and on third attempt it worked again! Those connectors are finicky and need encouragement
这个答案有帮助吗?
得分 0
添加一条评论
My fingerprint not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Murtagh 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 195
总计 19,814
