跳转到主内容
加入维修社区 - 创建账户
惠普高性能紧凑型台式电脑,具备完整的台式机功能。型号:600-a014。
PC won't boot up...
When I turned this PC on wednesday it tried to boot up but i get the message "Error: no boot disk has been detected or the disk has failed". I restarted it and pressed ESC then F2. My only options were memory test, which I did and it checked out ok, and hard drive check. I did the hard drive check and it tells me "no hard drive installed". So what'sup with that and how do I get this PC to boot up?
Mike @aactech are you out there? You've rescued me before!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
that would indicate there is a problem with your C: drive.
The first thing to check would be that is is still connected since it is not seen at all by the OS. Remove it and re-seat it a couple of times to clean the contacts. If it still does not work, U have a dead system drive, OR you have a power problem to the drive, OR you have a problem on your motherboard.
Is it running. U should be able to feel or hear it running. If so, it is getting power.
Get an external drive enclosure and connect it to another computer.
If it is recognized and you can read it, you have a computer issue.
If it doesn't run, or it is not seen, it is trash.
If it is recognized, but U can't read it, it may be possible to recover files, but that is a senior class subject.
这个答案有帮助吗?
得分 1
1条评论:
Is this solving the "no hard drive" issue, no boot disc issue, or are they both related? Obviously I'm pretty green at this but not afraid to get my hands dirty.
由完成的 分享
添加一条评论
It looks like your computer is attempting a PXE boot, which means it's searching your home network for a server image to boot from. The error is because no such network server exists.
Configure your computer to boot to Windows instead. Turn on your computer again, but this time, press ESC and then F9. If you see your Windows installation on the list of boot options, select it to boot to Windows.
If you don't see your Windows installation on the list, you may have to reinstall Windows. Ifixit has a guide for installing Windows 10 below:
How to install Windows 10 over USB - iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Sersig 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 622
