跳转到主内容
加入维修社区 - 创建账户
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Screen cracks when opening
Hello. I changed the screen of a macbook and I realized that when I open and close the screen quickly (normaly, like if it's the first time you open your mac), there are no problems. But if I move it gently to reposition the screen higher or lower and therefore go more slowly when I move it, it makes a little creak when I start to move it. I hope I explained myself clearly enough. Any explanations/solutions? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
It might be worth cleaning the hinges with isopropyl alcohol from the inside as there could be debris caught in them
Here’s the guide for getting the display off
2020年下半年 13寸 MacBook Air 显示屏更换
I would stay away from lubricants as they could remove the tension/stiffness of the hinges
Also if you go ahead with the isopropyl alcohol make sure to use it with a soft cloth in small amounts as it can get behind the display if you aren’t careful which can cause watermarks on the display behind the glass
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Thibaut 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 207
