跳转到主内容
蘋果2020年的主流 iPhone 機型,發布於10月23日,搭載6.1吋 OLED 螢幕及12MP 雙鏡頭模組,有著5種顏色。該機型為 iPhone 11的後繼產品。
Is this damaged or can I use it?
I am replacing the display IC from the original screen and scraped away the black layer of adhesive and what could have been the top layer of the chip. Is this still usable after reballing or is it damaged. Very new to this stuff. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi
When removing chips you will get some minor defects
It your case it looks ok as I can’t see any obvious bits of exposed copper or any chipped or dented bits of the chip
If you want to you could apply a very very thin layer of solder mask where it has been removed (if you do make sure to not get it in the pads,if you do you can carefully scrape it off the pads)to help if you have any on hand
I would put the chip on(after Reballing)and see if it works and if it doesn’t replace it with a new one as small chips like this aren’t expensive to replace:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
1条评论:
@hellomacos is correct. Apply solder mask than re-ball the IC as it does not seem damaged.
完成的
添加一条评论
I wouldn't take a chance and waste your time the chip is only a couple of dollars so I would just replace it with a new one.
这个答案有帮助吗?
得分 0
1条评论:
Reball it and try it. Doesn't look too bad to be honest. You've gone this far. Let us know the outcome. Good luck.
完成的
添加一条评论
添加你的答案
Salmaan Yehia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 219
