跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
99 个问题 查看全部
Apple Cinema Display 30" - Detected but not powering on
Hi there,
I just purchased two Apple Cinema Displays - both "30". I checked each display before I bought it -- worked perfectly. However, after driving home with the displays and plugging each into my MBP M1 via a separate USB-C to Dual DVI adapter, one display works perfectly (and is detected as Cinema HD), but the other display is showing just a black screen, and the LED power indicator is also dark, and is detected, but not as a Cinema HD display, but as "Display". Any ideas on what I should do?
This is what the System Information shows:
Apple M1 Pro:
  Chipset Model: Apple M1 Pro
  Type: GPU
  Bus: Built-In
  Total Number of Cores: 14
  Vendor: Apple (0x106b)
  Metal Family: Supported, Metal GPUFamily Apple 7
  Displays:
Cinema HD:
  Resolution: 2560 x 1600
  UI Looks like: 2560 x 1600 @ 60.00Hz
  Main Display: Yes
  Mirror: On
  Mirror Status: Master Mirror
  Online: Yes
  Rotation: Supported
Display:
  Mirror: On
  Mirror Status: Hardware Mirror
  Online: Yes
  Rotation: Supported
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Do you have a multimeter?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi
I have one of these too (with the same issue)and I have found that if I use a adapter to put it in a different port(in my case it’s DVI to HDMI)it will work just fine again
I don’t think it’s a problem with the display,I think it’s just a strange case of it acting strange and not communicating with the computer/GPU correctly
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Twister Murchison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 458
