跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Boot looping on charge
Hi. My phone dropped. iPhone 7+.
It boot loops while on charge, and it can move to dfu mode still on charge. But when removed from charge, it doesn't work in any way.
Doesn't boot without the charger, and no going to recovery mode/dfu mode without charger.
What is the problem guys?
And how would i fix it?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
When I see this sort of issue it is usually a battery related issue
To fix this you will need to replace the battery
Here's the guide you will need to do that
更换iPhone 7 Plus的电池
Also heres a link to the part you will need
iPhone 7 Plus Battery
Hopefully this helps
Any questions please ask
iPhone 7 Plus battery replacement kit. 100% factory tested, 2900 mAh high-quality battery. No soldering required. Compatible with all iPhone 7 Plus models (not iPhone 7).图片
产品
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Abdulhalim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
