Well When I Put My Dyson To Charge It Doesn't Charge
I Think It Is Not Normal
@sebastianputura check the charger itself first. Make sure it is plugged in etc. Then check the connection between the Dyson and the charger. Make sure they connect properly and nothing is obstructing the charging port. After that, you may have to try a new battery.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 64
4条评论
Hi
Do you get a light in the charger?
Also have you tried a different battery?
由 HelloMacOS 完成的
No I Don't get a light in the charger
由 Sebastian 完成的
No I haven't tried a different battery
由 Sebastian 完成的
@sebastianputura
Do you have a different battery or charger to try?
由 HelloMacOS 完成的
