跳转到主内容
加入维修社区 - 创建账户
Lenovo B 系列办公笔记本电脑的维修指南及支持信息。
Boot menu empty and bios can't load default
Pls help me out. I have lenovo laptop with ssd and hdd in my hdd i install kali linux and ssd window. By my mistake windows was corrupt and now I can't boot it... The main problem is in my boot menu not any external internal device show only it show kali option which will boot and open grub menu of kali where I can have kali linux and window option. I can boot kali linux and it working file and as I tell u my window can't boot its show error.
Now problem is I want to install Windows again but can't becoz my bootablependrive not showing in boot menu and i try everything.But can't get help i open bios but i don't know how but i can't change anything in bios and i can't load default and eventually I bios boot order only kali is show. Usb hdd ssd nothing is showing. I also try with removing cmos battery for 1 hour so i thought it reset my bios then it will show my pendrive in boot menu but this also not work for me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
can you see if it says legacy or uefi in bios boot options ?
完成的
Uefi but as I said I also can't make any change in bios.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Press C when your GRUB boot menu appears to open the GRUB command shell. From GRUB rescue prompt using the fwsetup command you should be able to enter UEFI BIOS.
Once in UEFI setup, remove boot option for GRUB. This will restore Windows Boot Loader as the default bootloader.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peter Parker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,065
