跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1216 个问题 查看全部
PLEASE HELP!Attempting to fix my screen, lifting to inside of screen.
My screen got a crack in it. So I decided to replace it. When lifting the screen to get into the phone, instead of lifting ALL of it up, it is just lifting the display itself up... I don't want to be on the inside of the screen, rather the inside of the phone. PLEASE HELP!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Okay Joseph, calm down, it's okay.
First off, usually the reason the LCD separates from its frame is that you neglected to take out the Pentalobe screws securing the frame to the case. You did take them out, right? If not, do that now, before anything else.
Now, assuming you've got the LCD mostly off, you've got two choices. You can finish the job (you're replacing it anyway, right?) then tackle the frame that's still on the phone, or you can go back around the phone and make sure you're under the frame this time and free it all up that way.
This is what your phone will look like if you take the LCD off without the frame.
Versus the inside without the display frame.
You're not the first to run into this; here's another post from someone who had the exact same thing happen.
SOLVED: Why does the inside of my iPhone x look different than everyone elses? - iPhone X - iFixit
You'll be fine once you have the frame and the LCD off; nothing you're doing will damage the rest of the phone, only the old LCD that you're replacing anyway.
Let us know how it goes.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joesph Dunne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 274
