Why is my Zealot S30 Bluetooth speaker not turning on
After charging my Zealot S30 Bluetooth speaker today for some hours, I tried turning it on but it won't come on. It charges but it just simply won't turn on.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 119
Abdullahi Abdulkareem how old is the speaker? Do the LED's come on at all? Do you have any sign of life on the speaker?
由 oldturkey03 完成的
@oldturkey03 the speaker is over a year old now. 1yr and 4months old. It charges when I plug a charger to it. The red charging notification LED light comes on. But when I try to turn it on it doesn't respond. The blue LED notification light indicating it's turned on doesn't come up.
由 Abdullahi Abdulkareem 完成的
The same situation with "Zealot S51"! Reset button is not in aux jack nor in blue led or in microphone hole :( None of possible simultaneously pressed button combination doesnt work. Any solution? :(
由 Pavel Fojtík 完成的
I completely drained the battery. And now it works fine. But I hope this is not the only solution for the future.
由 Pavel Fojtík 完成的
@pavel How do you drain the battery when it doesn’t turn on?
由 BOBLASHI 完成的
显示更多的1条评论
