跳转到主内容
加入维修社区 - 创建账户
Google Pixel 6 的维修及拆解信息。机器型号为 GB7N6 和 G9S9B16。
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
完成的
添加一条评论
I have this same issue and also when I call someone the screen flickers
这个答案有帮助吗?
得分 0
添加一条评论
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Davide Di Nello 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,008
