Why is my phone not charging
Troubleshoot your cable, charger, outlet & case
Check that your charger and cable work. Try them with another device. Check that the cable is securely connected to the charger and to your phone. Check that there's nothing in the port of your phone, like dust or lint.
Regards,
这个答案有帮助吗?
Most of the time but not all of the time it's because the charging port it's self is malfunctioning or broken, or the phone has been plugged in and used too much .when it's plugged in to charge the wiggling of the cord and the temperature of the plug over heating the port cause it to lose connection and stop working. And like most people I've talked to like their phones but have no clue where to take them to have them fixed,well now that you can get the proper tool kits for phones from here and can buy the charger port off of ebay or Amazon for any where between $6-$30 you can save your self a big charge taking it to your provider and do the same Job yourself and in the process learn more about your phone and how to fix the issue again or on a friend's phone. YouTube has all the DIY videos on most to all phones,so fixing this issue is way less stressful.
这个答案有帮助吗?
Try a restart. My Galaxy went from 15 to 96%, just like that. Not a great portend for this new phone. "/
You do is the connector are broken or blew a fews now I know the connector are the problem
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 558
5条评论
We need a bit more info. What does the phone do? Does it turn on, vibrate, or make any sounds?
由 guardian10 完成的
I have a question my Samsung A02s is not charging anymore what the problem with it
由 Edin Cerritos 完成的
I have a similar problem but it has to be in a Cretan direchen
由 Phillip Norton 完成的
@Phillip Norton what model is your phone. It sounds like a bad charging port. Let us know the model and I am sure we can guide you to a good repair
由 oldturkey03 完成的
Yes, my mobile is not charging, the issue of temperature is coming, it will be four days
由 Ahmar Abbasi 完成的
