Not able to lift the call
I get the vibration but not able to see the incoming call details and not able to lift the call
Could be just a configuration issue; on pre-Android Pie (Android 9) phones, which should be your case, here's what you should check:
go to Settings menu, open Apps, then Notifications, make sure the switch is flipped on.
Also make sure Incoming calls permission is on and importance is set to Urgent
Reference tutorial here.
If this doesn't solve it, there could be something interfering with the proximity sensor's functionality. At this link you'll find some useful tips give them a try, for a quick sensor test you can also go with the built-in diagnostic tool, should be accessible by simply dialing the code ##0588#*#*.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 182
3条评论
Not support software
由 Maya Kannan 完成的
Maya, if you're looking for help, you'll need to give us a lot more to go on; the better your description of the problem you're having, the better your answers will be.
由 Jerry Wheeler 完成的
Mere mobile ka folder kharab ho
由 Idrish Patel 完成的
