跳转到主内容
Manufacturer Part Number 100015685 Serial Number: G5KDCZ0670L5
16 个问题 查看全部
Touchpad shuts down for no reason
The model above is different, selected it because they don't have mine. Mine is an Onn 10" touchpad with keyboard attachment, Manufacturing part no. 100005209 Serial no. 5209908067754 . Front and rear camera with micro SD card slot and micro USB input. Ok. Let's get to the problem.
So when I just play a tone (notification for example), it just stops and the screen turns off. Press and hold power button, it boots up. So every time I put something like GPS on or sound on or even a notification, it just shuts down. No warning or anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@anchefixes it sounds like you are saying that anything with sound will turn your tablet off. Do you still have full access to the settings? Have you tried a reset? What have you tired?
完成的
Nevermind! I took it apart and unplugged and replugged the battery and now it works surprisingly.
完成的
添加一条评论
1个答案
已选择的解决方案
Ok so I fixed it either by disconnecting and reconnecting the battery, or by pressing the reset button I noticed at the last second and holding it down for 60 secs, but I don't know which one did it because I did both at the same tim before powering it up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anchevauls Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 65
