跳转到主内容
Released in 2021, the Lenovo Ideapad Gaming 3 15ACH6 has a Ryzen processor and NVIDIA GeForce graphics. It is a budget gaming laptop.
What side is the SSd located where the OS is installed?
I'm going to upgrade my Ideapad Gaming 3 and was wondering what side of the motherboard is the default SSD is located and the size of the default drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
KEN BEN center right above the battery ;-) Looks like the 512GB SSD is the most common one. Download the maintenance manual for your Ideapad from here It will show you the location as well as what to do, to get there etc.
完成的
If its the center right of the battery then it would be 2242 right? if so, I'll have to buy a 2280 one and use that of my machine . Thanks for the answer.
完成的
添加一条评论
1个答案
最有帮助的答案
It took some digging, though I would confirm the exact model number before you take my research for certain, but based on some cross referencing between the Lenovo Service Manual and the parts lookup site it looks like it takes an m.2 PCIe 2242 type drive.
As for which side of the board it's on, even the Service manual doesn't specifysince I suspect there is some variance in configurations and 2242 is fairly small, though I would wager based on the images in the guide, it's on the right side if you're looking at the bottom of laptop, with the hinge facing up.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for the answer, If its in the right side then its safe to assume that I just have to buy m.2 2280 drive and I will have a place for the drive to fit and be used in my machine. Anyways thank you.
完成的
添加一条评论
添加你的答案
KEN BEN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 168
